RP Count for this group is already zero and is being decremented again which will result in a wrong value.
This error check is more of a consistency check and should not ideally happen. If you see this message, try disabling pim and re-enabling it to resolve the problem.
Critical
Function %function%: RP Count for Group %group% is ZERO and is being deremented.
| Name | Type |
| function | String |
| group | IPaddrN |
